Looking for a DAC demo board....
I'm in need of a DAC demo board that has either a high speed interface to it or some on board eprom I can program.
Looking to do some DAC testing and modifications thereof of DAC's in the range of 10 or 12-bit and at more then 20msps.
Some of the ones I've found from like ADI only have serial/parallel interfaces.. not fast enough to push
data to the dac's at anything faster then low audio speeds.
Can someone recommend a DAC demo board with a fast interface to it? like firewire or usb2.0 or one with
programmable eprom or similar memory?
thanks in advance.
frak
RE: Looking for a DAC demo board....
Check www.cygnal.com
cheap demo boards
µcontrollers ... > 25 MIPS , 12 bits ADC--DAC etc
(not sure for the 20msps DAC requirement)
Good luck
