Rip Rap Channel Design
Can someone point me in the right direction to find the Army Corp of Engineer literature regarding the design of reip-rap channels?  I've done a web search and come up empty, and their website isn't all that helpful.
If there are other documents regarding this subject, I would love to hear about them as well.
Shane
RE: Rip Rap Channel Design
I WOULDNT RECOMMEND WEST CONSULTANTS - THEY BILLED MY CREDIT CARD A MONTH AGO AND I STILL HAVENT RECEIVED MY SOFTWARE
Riprap channel design using Manning's equation is pretty straight forward:
n=d^(1/6) / [21.6 log(d/d50) + 14], where d = flow depth (NOT channel depth) in feet and d50 = average rock size, as follows:
NSA size    d50, ft
R1    0.0625
R2    0.125
R3    0.25
R4    0.5
R5    0.75
R6    1
R7    1.25
R8    1.5
You will have to run a few iterations to get n, but 0.07-0.10 are good starting points.
Size for velocity (under 10% long. slope, s) or shear (over 10%):
NSA size    v, fps    shear, lb/ft = Shear stress = d x s x density of liquid
R1        2.5      0.25
R2        4.5    0.5
R3        6.5    1
R4        9    2
R5        11.5    3
R6        13    4
R7        14.5    5
R8        14.5    8
It should be noted that R1 and R2 are generally not accepted in central PA, because they are not really available (small graded stone is usually classed by AASHTO or a DOT system).  Also, for all but the largest of projects, riprap is not actually graded, so spec on the high side (higher NSA #).  Finally, when costing out riprap versus synthetic liners, add a significant amount for machine placement, as the per ton or cf price is just what it will cost your client to have a big pile of rocks dumped in her driveway, not what is will cost labourers and machines working all week to place the stuff.  In reality, a reno mat is easier to place than R7 or R8.  After adding in the aesthetics of the final product (grass versus rocks), I usually go with a synthetic liner.
A reference I have found very helpful is "River and Channel Revetments: A Design Manual",by Manuela Escarameia, published by Thomas Telford, London.
