motor IP65 rating
motor IP65 rating
I am looking for a good resource for IP65 rated motors with CE Mark.
I require 2 motors.
One will be 1/3 HP 230Vac 50Hz and will operate a circulator pump.
The second will be 1/2HP 180Vdc 50 Hz and will operate a product pump.
Both will be continuous duty and serve in laboratory batch processing equipment.
Any leads would be appreciated.
I require 2 motors.
RE: motor IP65 rating
http://www.reliance.com/pdf_elements/b4518.pdf
etc. for more info
Brushed dc motors to IP65 could be problematic especially if they are on for long duty periods. The brushes in totally-enclosed dc motors have to be a hard carbon grade to prevent dust build-up, this may lead to higher commutator wear or frequent maintenance. A brushless dc motor might be a better solution.
