ovality
ovality
ovality
i am working in kellenberger external cylindrical grinding
m/c, i grind valve parts which is very precise.
i face ovality problem(using expansion mandrels) as the wall thickness is about 5-8mm, does any of u faced this,
please share ur ideas..
RE: ovality
Are your mandrels being over-applied or tightened?
RE: ovality
dear ornerynorsk,
we apply minimum pressure as well as we tried other type of clamping too, still we r getting ovality of .001 to .002 mm
ragavan
RE: ovality
Have you tried to use an hydraulic arbor?
