Respecify Starting Curve in Rules Sheet
Greetings.
I am having problems respecifying the starting curve of a ruled sheet.
I have a sketch defining one airfoil (the root), and another sketch defining the tip airfoil. From these two curves (in modeling), I create a ruled surface between them to create my wing skin. From this skin, I trim out the rudder surfaces, and trim the original skin to other surfaces as well.
Now I want to re-define my airfoil. I am brining in airfoils as splines, defined as points. I go to my original sketch, and import the new airfoil. Now I want to respecify my curves defining my wing skin.
I have tried clicking on "Respecify Starting Curve", but id does not allow me to pick my new airfoil. I have also tried removing the string (the old airfoil) and adding a new string (the new airfoil), and it gives me a "Face does not intersect face of too." in my original ruled surface.
Is there something I am doing wrong, or is there a better way to redefine my skin surface based on my new airfoils?
I need to redefine my airfoils so that I do not have to back and retrim all my surfaces.
Any help will be greatly appreciated!
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
RE: Respecify Starting Curve in Rules Sheet
I think this is where I got hung up. The whole procedure seems very awkward, and by no means straight forward. I guess I learn something new every day!
Thanks again for your help!
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
Glad you figured it out.
