Cincinnati 5VC750
Cincinnati 5VC750
I`ve got two machining centres, Cincinnati 5VC750 with Acramatic 900MC V2 control. They have been standing idle for a long time and the memory was lost so I have to reload by tapes, in correct sequence. The problem is that the ID markings on the tapes are lost! Anyone who knows which is which? There are four reels, and all with different amounts of tape on them, so identification should be pretty straightforward.
Thanks!
Thanks!
RE: Cincinnati 5VC750
Merry Christams first...Did you get your 5VC running ? I have 3 of these machines and know them inside out. I can point you in the right direction, I have all the OEM manuals that I'm willing to copy the sections for you.
www.rimmetics.com
Happy Holidays.... Gary
www.rimnetics.com
Gary
1-800-934-0735
listen to the prompts for technical support.
This will get you to someone who may be of help.
