I HAVE A FORMULA FOR DIRECTLY GETTING THE AREA OF STEEL
hello,
  i want to know if there are no ACI Charts avaiable for getting the values of "row" or As ( area of steel ) then is there any direct formula for finding this if we have the Moment Mu or Ku avaiable in case of footing design. I have a formula but i want to confirm it with you guys please help me out :-
   row = 1/m ( 1- under-root 1-ku/F)  , here m = fy/0.85f'c and F= 0.3825f'c. is it correct to use this or is there any other formula for finding the area of steel and then spacing of the bars in case of foundation design
RE: I HAVE A FORMULA FOR DIRECTLY GETTING THE AREA OF STEEL
A convenient rule of thumb is:
As = Mu/4d
where Mu is in k-ft units, d is in inches
This will usually get you within a few percent of the exact answer.
The formula that I've gotten accustom to using is below.  See Wang and Salmon for further clarification...
m = (fy/(0.85*f'c)) and
Ru = Mu/(phi*b*d^2) and
Rho = (1/m)*(1-SQRT(1-((2*m*Ru)/fy)))
can you explain the derivation of As = Mu/4d?
thanks
The rule of thumb is easy to derive.  The equation for flexural strength of a singly-reinforced rectangular concrete beam is:
Mu = phi*Mn = phi*As*fy*(d-a/2)/12
now substitute these values:
phi = 0.9
fy = 60 ksi
(d-a/2) = 0.9d
Therefore, As = Mu/(4d).  Like I said, it's just a rule-of-thumb.  But it almost always is within a few percent of the exact answer if you just need a quick & dirty calculation for a reality check.
Taro ,
  how u got the value of (d-a/2) how u supposed the value of a.
sadman,
taro's value of 0.9d is an APPROXIMATE value of (d-a/2) and is NOT exact - as he clearly stated. re-arranging it is based upon "a" not exceeding 0.2d - ie ku=0.2
this is a very common approximation, and is okay for sections that are not "over-reinforced" and hence they are ductile and the neutral axis depth (or parameter, ku) is small.
it also works fine for T-sections provided the NA is in the compression flange!
I have come across a formula in one of the Indian Technical Publications wherein you can find Ast directly if you Know
Mu= Moment of resistance in N-mm
Fck= Characteristic strength of concrete in N/MM2
Fy= Yield strength of Steel in N/mm2
b= width of section in mms
d= eff. depth in mms
than,
Ast=(0.5*fck*b*d/fy)*(1-sqrt(1-(4.6*Mu/(fck*b*d*d))
