Equivalent BAC code for HL19PB70-6-10
Anyone know the equivalent BAC code for the Hilok HL19PB70-6-10?
Equivalent BAC code for HL19PB70-6-10Equivalent BAC code for HL19PB70-6-10(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Equivalent BAC code for HL19PB70-6-10
HL19PB70-6-10 = Pin BACB30FN-6-10 + Collar BACC30M6
The HL Part number is for a Hi-loc and Collar combination.
HL19PB-6-10 + HL70-6
Is the spec D-590 available somewhere?
It is online at My Boeing Fleet. ($$$$$)
We are low tech (less $$) and get a microfilm tape from Boeing Tech Pub Support.
sub fastener is s4931919-6-( ) as per matl sub manual.
Later ace
The "tension" application HL86 collar should never be used with shear head pins (such as the HL19: http://www.hi-shear.com/standards/hl19.pdf) as the preload developed by the tension-application collar torque-off value can overstress, or even fail, the shear head pin.
The HL19 (as noted by UG24U) is a cadmium plated, alloy steel, 100° Flush Shear Head Hi-Lok Pin. The Hi-Lok Pin has a hex recess in the threaded end of the pin that accepts a hex key to facilitate installation (prevent fastener rotation) during torquing of the collar in clearance fit installations (see bottom of page at http://www.hi-shear.com/fastener_hl.htm). The pin can also be installed in interference fit holes (and the collar installed without the use of a hex key).
The S4931919 "MD" Pin (http://www.huck.com/aerospace/products/threaded/mdpins/) which is identified by UG24U as a substitute part for the HL19 Hi-Lok Pin is a 6Al-4V titanium crown flush shear head threaded pin. It does not have the hex recess of the Hi-Lok pin and is intended solely for installation in interference fit installations. While there’s nothing “wrong” with this part, it is not a direct (or even necessarily good) substitution where the HL19PB has been called out…
In short:
rerig = good advice
UG24U = ???
