50KHz ultrasonic driver techniques
I have on my bench a stainless steel plate with a piezo ceramic transducer (50mm diam 5mm thick) bonded to it.
I need to build an efficient driver to pump power at 50KHz into the device. The end product will deliver ultrasonic energy into a glass container to excite particles suspended in a liquid.
The transducer is a two wire device.
Initial tests show the structure is sharply resonant at about 50 and 100KHz at which frequencies I detect activity in the liquid.
This activity dies if the frequency shifts by more than 0.2% either side of the resonant frequency.
Temperature changes in the stainless steel and transducer assembly can shift the resonant frequency by more than 0.2%.
Are there any text book techniques which I ought to know before designing the driver?
Suggestions welcome!
Electricliff
Electricliff
RE: 50KHz ultrasonic driver techniques
<nbucska@pcperipherals.com>
That was my first thought and the first attempt.
Unfortunately it would need to be a power oscillator because the drive requirement is about 30 Watts.
Have used a power amplifier to drive the piezo element and find that at 56KHz we get the desired activity in the specimen.
Unfortunately the resonances in the system (and there are a few!!)are not at this frequency. Do you call it Sod's law or Murphy's Law?
It looks like we are stuck with either driving our "off the shelf" unit with a home brewed power amp (the one we used for the experiment is very nicely boxed and full of expensive looking bits!!!)or hunting for a piezo ceramic assembly with a natural resonance at 56KHz.
I favour sticking with the "off the shelf" unit and designing a minimalist power amplifier driven by a tweakable front end oscillator.
I guess my real problem is knowing how minimalist you can be with these power piezo devices.
Do I need to concentrate on a low distortion push-pull design capable of emulating the expensive box we used for the experiments? Or can I just hit it with high energy pulses and let the properties of the piezo element convert these into the required input to the liquid?
I like you are semi-retired and have a few patents to my name, but ultrasonics has never been part of my love affair with electronic engineering.
Just thought someone on the Eng-Tips site might have experience of these things and point me in the right direction.
The problem was thrown at me by my old firm, who think I have time on my hands to pursue these things without it costing them an arm and a leg! And I like the challenge anyway.
But the solution must be inexpensive so I guess I need to start experimenting with single ended transformer coupled pulse generators and find out what happens.
Thanks for your input.
Electricliff
use this as frequency determining element. The other
resonances you can suppress. I suggest you look up
older patents at <www.uspto.gov> or other literature.
I don't think distortion is critical, Class-"C" should be
OK.
If you want a frequency different from the self-resonance
of the xducer, it means MUCH more power loss...
The frequency does shift with temperature and not surprisingly the temperature rises due to the 30 watt input.
I will start searching the data base!
Thanks again
Electricliff
