spring simulation
spring simulation
hi evreybody
I wanna to simulate a helical compression spring part
model.spring is oriented vertically and I wanted to
press it from top for a certain distance.how can I do
that?
Thank you!
bye
that?
Thank you!
bye
RE: spring simulation
You cannot do this with SolidWorks. SolidWorks does not completely integrate elastic analysis with its design, modeling and drafting system.
You can do what I do, which is create multiple configurations of the spring, representing free height, solid height and the various heights that will occur in your design. If you use a design table, you can analyze for force and stress. I suspect that this is what you are after.
I have not played with CosmosWorks. There may be something you could do with that.
JHG
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
I have tried what u have suggested.
I have yet to try it with Cosmosworks.
Lets c..
bye,
Thanks again!
make your spring design equation dependent, controling the pitch in relation to whatever dimension controls the spring extension (can be other part's mating dimension)
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
