what is diamond pin?
hi friends!
I am new in jigs & fixture designing.I am not getting,
why diamond pin is used for location with round locating
pin? why not another round pin? anything in detail with
technical clarity will be appreciated.
bye
bye
RE: what is diamond pin?
Two round locating holes with diameters closely sized to the locating holes diameters may not always accept the allowable distance variation between them.
Remember...
"If you don't use your head,
your going to have to use your feet."
Typically this is called a two-way locator as it locates the part in the up-down or left-right (only two of four ways) direction. This is opposed to a round pin which is a four way locator. You can't move the hole in the left-right and up-down directions.
This is commonly used to create your part alignment on the B-C datum line (In CMM speak this creates your line.) The round pin is your four-way locator which defines the origin of the part (Your origin or point from which all other points are relative). The diamond allows you to properly align one of the axis of your co-ordinate system through the center of the hole without making the part extremely difficult to load onto the fixture.
bye,Good day!
