Projecting an array of circlular protrusions onto a curve?
I want to project an array of circular protrusions 2mm from the face of part of a sphere. I was trying to do this with the normal protrusion but I didn't have much luck, and I was unable to select the curve. I also tried to use a pattern and a lofted protrusion.
I am quite new to SE, I am using SE12.
RE: Projecting an array of circlular protrusions onto a curve?
step 2 project curve on the sphere
step 3 normal protrusion
step 4 pattern
this is the way I would try it
Revolved protrusions using Open Profiles are enormously powerful.
