AutoCAD drawing viewer problem
When I go to open an archived drawing by AutoCAD my viewer works sometimes and sometimes doesn't. Has others had this problem? Is there some kind of setting for this? If I open the drawing and then resave it, the viewer then works for that drawing. What can be the problem?
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
RE: AutoCAD drawing viewer problem
Can it because the file is a block...
SpeedCAD.....
No it is not a block. These are archived drawings on our network drive saved under the job file folder.
AFab.....
We thought of that too and viewer seems to work for awhile when drawing is saved under latest version of AutoCAD. But days/weeks later same problem recurs with same drawing. There are presently only two of us Control Engineers and we both have same version of AutoCAD. However, there are other engineers/managers having access to these drawings and I suppose they could be on different version of AutoCAD. But this would upset me if I found out they are "saving" our drawings when open/closing as they are not qualified to do so.
David Baird
mrbaird@hotmail.com
EET degree.
Because this is my case: I open an Autocad drawing and see nothing... if I select something imaginary on the screen I start seeing the grips and the highlighted lines in my drawing. If I plot the drawing it comes ok on the paper ! Only the zooms and the image itself are dead !!
In my case I suspect it is becauuse I have the tendency to open too many programs in the same time. Usually after I close everything and open again only Autocad everything is fine...
Yes, the preview window. Our typical schematic package for a job contains from 12 to 24 drawings all saved under the job folder for the S.O. Say I want to later go back to a particular drawing and don't remember which sheet out of the package it was. Consequently, I want to click on/highlight each drawing one at a time to view in the preview screen tell I come to the drawing I'm after. My viewer for this preview window does not always work. So then I must open each drawing tell I find the right one. A very time consuming effort!!
David Baird
mrbaird@hotmail.com
EET degree.
but ours will not allow us to view
the drawing if someone has opened
the drawing in acad on their computer.
We have to go to the administrator to
see who has it open. Nice system.
Try to zoom in until you can see what you need to see and try again,maybe that helps, that works for me when i save blocks
