Lock the form size
Lock the form size
Lock the form size
Is there a way to lock the form size in VB6? I use the following code right now but it produces a runtime error if you attempt to minimize the form which the users must be able to do.
Private Sub Form_Resize()
   Form1.Height = 8175
   Form1.Width = 8550
End Sub
RE: Lock the form size
You will have to put in a check to see what the window state is before allowing the code to run.
Just put On Error Resume Next as the first line in Form_Resize
Or, better still, in the Form properties make BorderStyle 1 and MinButton true then you do not need the resize event at all.
Thanks for the help. They are all good solutions but I have to give the most credit to FrancisL for his second post as it is the way it should be done.
I should have found this solution myself.
Time is the fire in which we burn.
