Selective load of components
HI
When you open a CATProduct is it possible for it to automatically load only certain Components on activation?
I have load referenced documents switched off.
Chris Dixon
Design Engineer/Catia Administrator
Alstom Power
RE: Selective load of components
Yup,
One way is to go to your options/product structure/product visualization and select "do not activate default shapes open"
You can then manually select the products you would like to load.
Hope this helps!
