Tar pump seals
Tar pump seals
Tar pump seals
Gents,
we are having lots of problems with the existing single seal for the tar bottom pumps in steam cracker plant. it is pusher type single seal plan 11 (changed to 32) , the seal faces hang up ,  O'ring got damaged .....etc..
i am planning to upgrade it to dual seal plan 32/62 any bodey has good experince with this arrangment.
product is process water + 10% HC
temp. 150 deg. C
duble suction pump
PH 5-9
solids about 900ppm
pls. let me know
upm
