reading drive a: all the time
How do I stop autocad from searching drive a: first, every time I look for a drawing?
reading drive a: all the timereading drive a: all the time(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: reading drive a: all the time
You could try this:
Change the Default Drawing Folder
Each time you start AutoCAD, the last used paths in each particular standard file selection dialog box are remembered across AutoCAD sessions. Alternatively, you can configure AutoCAD to always default to a particular path by changing the default drawing folder.
To change the default drawing folder
Set the REMEMBERFOLDERS system variable to 0.
On the Windows desktop, right-click the AutoCAD icon. Then choose Properties.
Choose the Shortcut tab.
In the Start In box, enter the path of the folder that should be the default when you open or save drawing files.
Choose OK.
REMEMBERFOLDERS Controls the default path for the Look In or Save In option in standard file selection dialog boxes
Tom
