Looking for RJ45 physical switch.
Can anyone point me in a direction for a single pole double throw switch to switch between 2 RJ45 connections?
Thx in advance,
Tef
RE: Looking for RJ45 physical switch.
I'm assuming that you are merely trying to select between two different unpowered circuits, be careful if you plan on live switching or transferring between operating circuits.  Try Blackbox or googling on RJ45 transfer switches.
Thanks RAMConsult.  Had checked Black Box prior to vacation.  They say the do not have one.  The circuit I am switching consists of a proprietary keypad / programming port which is designed for removal under power.
Try www.kristamicro.com they sell a wide variety of switch boxes.  I've also gotten lucky at computer or ham radio shows in my area.
