Section Arrows in a Dwg.
All,
I'm new at SW. I've placed my first view and I want
to create a full section view, but I can't place my section line directly on the centerline of my initial view. I must place the section line then dimension it from an edge. Is there a quick way to place the section line right on a centerline? Is there a way to make the section line collinear to a centerline?
Thanks in advance for the help.
Matt B.
Matt B.
RE: Section Arrows in a Dwg.
Then while holding down the CTRL-key, select the centerline on the drawing view and either the origin or a plane from the part out of the Feature Manager.
Mate them colinear and then hit the section icon while the line is still highlighted.
Remember...
"If you don't use your head,
your going to have to use your feet."
