Common production suspension materials
I am trying to determine whether the welded pressed-steel box-section trailing arms and subframes on an eighties BMW (E30-chassis) would likely be mild steel or not. On the same note, which materials are commonly used on load-bearing members of currently produced mass-production vehicles?
RE: Common production suspension materials
