help me please
help me please
i have to set a gear measuring machine with a fixed master disk (it seems a croix) of 187.400mm base diameter.
i found mod.3.62595 and number of teeth 55 to get in a prog and it run well.
so the profile control it's ok for spur gear.
now, with the same base diameter, number of teeth and helix angle of 15 degree, what is the module that i have to get
in the pc?
nowadays i haven't found anything module to obtain a right control.
someone could help me?
thank you all in advance.
in the pc?
RE: help me please
The pressure angle is commonly 20 degrees, for:
- Straight toothing with increased loading capacity requirement - 25 to 28 degrees
- Helical toothing - up to 25 degrees
- Gearing with a special requirement for quietness - 15 to 17.5 degrees
Mirekp
http://www.mitcalc.com
Mechanical calculations
