water harvesting for sustainble agriculture
i am requesting information with regards to techniqueson rain water harvesting
RE: water harvesting for sustainble agriculture
changeable with a 540 shaft. I am looking for a gear-reducer type with a female input of 21 splines(that slides over the 1000 rpm shaft)and has an output shaft of 540. I know there is a stub shaft that slides over the existing 21 splined, 1000 rpm shaft that is a 6 splined shaft for the 540 rpm equipment. The problem with this is that you have to idle the tractor down and when you do this you lose horsepower and it lugs the engine. Any and all help would be greatly appreciated!
