BEAM BOTTOM FLANGE LOADING
If somebody could help me with a calculation exemple for a monorail beam or any similar beam loaded at bottom flange ?
NIck
NIck
RE: BEAM BOTTOM FLANGE LOADING
1- In the case of a welded I profile, usualy the weld is a fillet weld, with no pernetration, thus we can't count with the tensile stress along an axis perpendicular to the weld line. And this really happens in this loadind case.
2- Should we consider the slope of the bent flange and limit it to a maximum value? I guess that it is analoge to the alowable max relative deflection of the beam(1/600 in most cases) due to the resistance imposed to the movement of the crane car.
Any further discussion on this subject will be very apreciated.
Thanks and sorry for my bad english, I'm Brazilian.
Best
Fred
Another method which has been around for many years is a set of tables by a crane manufacturer called Wright for again underslung cranes. This is an excellent starting point. Given the load and span, the beam (A36) can be chosen in less than 5 minutes (one minute more likely) (deflection, overall bending, and concentrated stresses are considered). S, W, C+S built-up, and C+W built-up shapes are included.
Cantilevers should not exceed 25% of the maximum simple span. Curves should be analysed using a FE analysis.
Could you please tell where can I find this tables (Wright).
TIA
Fred
I don't know where you can get them (Wright tables), but I could scan the tables that I have. But how would I post them?
Would you please email me at fkdconsult@hotmail.com, I tryed to find them over the net but get it.
TIA
Fred
The method limits the transverse bending stress in the bottom flange due to load from the hoist. The are various variables that are required such as the number of wheels on the trolley and the set-in of the wheels on the flange. Rolled sections and plate girders can be analysed.
or as you asked for it, bottom flange loading desig.
Contact me via e-mail (ehcet@idirect.com) or by phone
905-712-2373
Regard Ernie
