AVIONIC AND RF
AVIONIC AND RF
AVIONIC AND RF
Hi, my name is David and I'm working on a power amplifiers to be used in avionic.The final equipment is already being used but we've discovered some problems related with the radiated pulsed energy.
Could anybody suggest a site, book, or anything where I could find precise information about the effect of height, temperature,vibration and pressure on microstrip and stripline transmission for 1030/1090 MHz pulsed power (62dBm) ?
Thanks in advance
DAVID AREVALO
RE: AVIONIC AND RF
With those frequencies it sound like you are working with IFF transponders? Do you have a specific problem?
RE: AVIONIC AND RF
several issues here. microstrip should be insensitive to all of your variables except possibly elevation as regards to power rating.
suspect that your are dealing with induced voltages more commonly associated with "cross-talk" between circuits. strip lines are notorious for pickup sensitivity unless properly shielded.
