Steam Powered Turbin Piping #2
About a week ago, I wrote a question about my employer putting a 1 3/8 pipe in place of a 5" one. The pipe that I said was incorrect, it should be 1 3/4. I asked if it was safe and if it would acutally reduce the amount of steam to lower the horsepower.. I would like to thank those that helped and ask this:
Someone had brought to my attention that this length of pipe should be 10 feet long to affectively reduce the horsepower. The pipe they installed is only a few inches long.. What I was wondering, if they install the pipe the right way, do you think this would reduce the scream of the steam going through it? If the pipe is suppose to be this long, isn't it unsafe being this short?
I have brought my concerns to the safety board that my employer has set up, and they have said that they are working on a way to try to insulate the noise. They said that they checked the DBA's in the area and have found it to be within regulations. The problem is, I don't know when they tested it, or if they even tested it at all. They could've tested it when both turbins were at an idle or even when they weren't running.. I know that when the turbins are running near top RPM, the steam going through that pipe can't be with in reguations..
I have a feeling that this is going to be a fight, but I can not sit here and let them destroy my hearing.. I am trying to gather enough information to bring to OSHA..
Any help with be great appreciated..
Thanks again..
Chappy
Thanks again..
Chappy
RE: Steam Powered Turbin Piping #2
