Engineering units in Excel
I'm sure this questions has been asked before, I just can't find any answer.
How can I get Excel to work with engineering units for data in/output.
being able to write something like 1.5k * 5u and get 7.5m as an answer.
Are there any fancy macros or something like it available to do these things?
Andreas
RE: Engineering units in Excel
Not as a general rule.  You can potentially write your own, but it would seem to be easier to get something like Mathcad.
TTFN
Why don't you just use custom formats for the cells:
<Format> <Cells>
select tab "Number"
select "Custom" from the list
type 0,00 "u" in the "type box"
do the same thing for the other units.
You have to tell your computer the units anyway even in mathcad.
Hope this helps.
regards
Mogens
That is true, but I like to have excel to use it in the calculations
Eg filling into a cell 1000 should then come up as 1k. Or entering 1000u should come up as 1m etc.
And the custom units won't help for that.
Andreas
