ballooning bug
ballooning bug
I have one assembly drawing that SW03SP4 will not balloon correctly. There are 3 views, two are of the same configuration, one is of a different configuration. The balloons number correctly for the view I've inserted the BOM for, but some of the balloons from the other two views are numbered incorrectly. If I delete the BOM and reinsert it for a different view, then those baloons are correct, and some of the other views' balloons are incorrect. The incorrect numbers are always off by 1. Which balloons are affected seems to be random. Even if I start a whole new drawing the problem doesn't go away. In my two years using Solidworks I've never had this problem before. Anyone know what's causing this?
RE: ballooning bug
I suggest you should check this first
RE: ballooning bug
RE: ballooning bug
RE: ballooning bug
Ken
RE: ballooning bug
RE: ballooning bug
