Steel pinion vs. plastic
This is a fallow up question from the students that are building the high mileage car. In a coast and burn situation where the engine is on for 3 second and off for 45 seconds while reaching 6000 RPM, is a steel pinion nessessary? Because of the short amount of run time, low temperatures, and relatively low forces do you think plastic will be okay? The entire car only weighs 200 lbs. and only reaches speeds of 25 mph. The main reason that we like the plastic, is we have a small CNC machine and can mill our own parts. Not in steel. The Master CAM program that we have, will calculate simple spur gear profiles. What do you think? Please any sugestions are welcome. Thanks for your help!
RE: Steel pinion vs. plastic
