Microstation plotting
How do you print or plot to a USB only device from Microstation or DOS?
RE: Microstation plotting
USB should just connect ... using the "printer.plt" driver.
As for DOS...
at the DOS prompt type:
copy filename.plt ltp1
pretty much this means...
(copy DOS command-space-filename of plt file-space-address of the printer or plotter)
