using large deformation
How can I execute an analysis using with option "large deformation" (but no "large displacement"?). I work using MSC.Nastran for Windows.
Thank you for possible help
RE: using large deformation
You should define everything for the non linear analysis and in the analyses command just switch on "large displacement" switch.
On the MSC NASTRAn site you can find some examples!
