test of fiber composite
Could anyone suggest the tension test of fiber composite materials.? How it can be done and with which machine (UTM?) and what I can find the testing standards.? Thanks a lot in advance.
RE: test of fiber composite
We need a little more info to work from.  What type of fiber composite?  Is it a resin material?  Is it concrete?  Is it a "plastic" other than a typical resin?  What type of fiber?  Metal? Polyester? Polypropylene? Glass?
These different materials dictate different test methods and evaluation.
