SWIMMING POOL MECHANICAL DESIGNING?
HI FRIENDS. I AM A MECHANICAL ENGINEER FROM GREECE. I STARTED A JOB IN A CONSULTING FIRM LAST MONTH. I HAVE TOLD MY BOSS I AM FAMILIAR WITH DESIGING RECREATIONAL FACILITIES BEFORE. I THINK MY BOSS IS BIDDING FOR DESIGN OF A PUBLIC SWIMMING POOL. I WILL THANK YOU IF YOU CAN GIVE ME INFORMATION I NEED SPECIALLY ON LINE INFORMATION I CAN GET FORM INTERNET.
THANK YOU WITH YOUR HELP.
RE: SWIMMING POOL MECHANICAL DESIGNING?
If this is an indoor pool, or Natatorium, you will want to update yourself on design issues discussed in ASHRAE HVAC Applications (1999 or 2003).
Poolpak
Dry-o-tron
Decktron
are all pool equipment suppliers with design info.
Conditioning pool enclosures can be tricky. Approach with caution. Good luck....kgr
Another manufacturer, Desert-Aire, provides very good design information and design program.  The system will need to meet particular requirements, but those requirements are well-known and documented.  I agree you will want to review the ASHRAE guidelines.
timr
