Rubber sleeves for the 35000 rpm running machine !
Hi :
I have a question, by using the rubber sleeves in the bearing housing of the 35000 rpm running machine , I did provide some additional damping and the stiffnes that effect the reduction of over all motor vibration.
What I would like to know is your comments on this application ? Could the rebbure sleeves might effect the life of bearing and how coulld they react when they are used with the bearing springs in the housing ?
I look forward to receiving your responses.
Many thanks and best wishes.
Cuneyt Ozturk
