IDEAS TO AUTOCAD EXPORT
hi,
When I export a drawing from IDEAS to Autocad, most of my dimensions, views, text does not come in the proper postion and in proper format .. What may be the problem??
Any help is warmly appreciated
RE: IDEAS TO AUTOCAD EXPORT
Within Model all the views and text were dropped on top of each other whereas in Layout everytihing was correctly formatted.
Alternatively, which translator did you use? DWG gave me the best results with DXF running a close second. IGES was terrible.
First you need convert to "*.asc", smash all views and after convert to "*.dwg" or "*.dxf"
