Column Design Eccentricity
I have a 4"x4" HSS steel column, with a w-section beam framing into the side of the column (assuming double angle framing angles and bolts for connection).
I'm wondering what eccentricity do I assume in checking the column strength.  (The vertical load is placed at the center of the hss and the eccent. is accounted for by applying a moment at the top of magnitude(P*ecc))
Now do you assume that e = distance from face of column to centerline of column or is it from centerline of bolts on beam web to centerline of column??
RE: Column Design Eccentricity
Never mind, I did a search and found a thread from 2001.  Looks like I should use e = (cL of column to cL of bolts in beam web) and design for combined axial compression and bending.
Many codes specify a minimum eccentricity to design for, you might check for that as well.
