Torsion bar design help
Hi I am new to this group. I am looking for assistance on a torsion bar I need to manufacture. It is a replacement part on equipment I service. This bar is small (15mm long and about 3mm in diameter). This spring rotates a very small amount at a rate between 3 and 8 KHZ. The most important characteristic is it's ability to return to the starting position after energy is released. I had the metal analized. I was told it is similar to 4150. My plan is to but 4150 stock and grind the shape. My questions are, will this be the best way. Should this be heat treated after grinding. (I currently don't know the parts hardness). Any suggestions on this manufacture, the material selection would be appreciated.
Mark
Mark
RE: Torsion bar design help
