Place Note command
Place Note command
The options for text-frame while placing a note with the place multi-line note command are None, Box, and Line. The line is a vertical line. My employer requires a horizontal line going between the first and any subsequent lines of text contained in the note. Does anyone know of a way to customize this "line" to do this? As it stands, placing a note is time consuming.
