vibration test bed for a pcb
kt82 (Mechanical) Oct 10, 2003
i need to design a variable frequency mechanically powered test bed for vibration testing of electronic printed circuit boards after components are mounted. the system should be capable of varying frequency up to 3000Hz with an amplitude from 0 - 3 mm . motion should be harmonic.
im thinking maybe a table with a cam on one side and a spring on the other, how will i run this cam, wat type of motor do i need. also the table is going to move horizontallly so im goin to have it moving on sum sort of bearings,
please help
please help
RE: vibration test bed for a pcb
Cheers
Greg Locock
Unholtz-Dickie
Lansmont
MB Dynamics
Ling Dynamic Systems
TEAM Corp
MTS Systems
APS Dynamics
Tom Irvine
www.vibrationdata.com
