Weld Reliefs
Weld Reliefs
Weld Reliefs
Is there a standard reference for creating weld reliefs in the base material?  Thanks in advance for any help.
RE: Weld Reliefs
Do you mean welding short bead lengths for anti skidding or similar purposes? Many parameters would influence the outcome, so that I would be surprised to find a standard of reference except maybe for specialized applications.
In any case if you plan to weld such reliefs from one side of a sheet or plate, be prepared to deformations caused by tensile stresses parallel to the weld beads.
http://www.welding-advisers.com/
RE: Weld Reliefs
Weld relifs would simply be base metal buildup.  A weld symbol with a half circle bound by the reference line is the standard designator.  You would probably need to define extents of buildup in the tail of the symbol.  Such as---2 inch long beads on 6 inch centers with so many rows with the rows being staggered or directly parallel.
