Named Views Error
Named Views Error
When in model space I use zoom extents to view the image in there.
Generally, I choose the pulldown for iso view to see if anything is drawn in 3D. Once satisfied, then I pick the top view icon to return the image in a flat plan view. I use that in stead of view previous.
What occurs is a twist in the image. I have to undo, undo undo to get back where I was.
Does this indicate a corruption from an imported drawing file. Or is there a setting I'm over looking. This is for AutoCAD 2000.
Any ideas what causes this? Its' the first time I came across this anomaly.
Thanx. RW Frank
Thanx. RW Frank
RE: Named Views Error
My fix is laborious:
I setup World UCS draw a line, select and align all these objects to the line. After this little execrise I can rock an' roll to finish the job. I had hoped there was an easier method to my dilemma. Thank you for your input. It cast light on another overlooked issue.
-RW Frank
