how to rotate entire part model
i already finished one entire part model , but my client needs that model's particular face should be front side view.
for i will have to rotate the entire model 90 degrees or any degrees.
is there any special tool to rotate entire model (like autocad 3d rotate).but solidworks is parametric tool. is it possible?
i can rotate single feature using rotate tool.
but for total part model rotation, any special procedure?
using rotation tool,it is posible to select all features. at the same time it is not selecting planes.
if i used mirror part , that new file is refering parent file.
if i use edit sketch plane it is changing the paticular feature only.
if i use view orientation for showing required face as front side.
it is working. but if i click "reset the view orientation" it is showing original model.
thanks,
regards,
murugan.S
thanks,
regards,
murugan.S
RE: how to rotate entire part model
Or, can leave the Views as they are, and just insert a Named View of your model into your Drawing. Check out SW help.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
1. Right click on your "Sketch" and select "Edit Sketch Plane"
2. Click on "Sketch Plane" to show "FeatureManager" and select a plane as a front. (You can click the title or bottom tab.)
This way, when you make a drawing, front view comes up properly and also, "Orientation" when you hit "Space Bar" follows and appears correctly too without renaming or creating new one.
hope this work for you
then we used suface cut.
any comments?
thanks
regards,
murugan
What you have now done with your current solution if I understand correctly is created another part model based on the original model. Essentially a derived part. Now you have two models, one for show and one to work on. Seems redundant to me.
i have done the part using mirror all concept.
here no need to worry about the derived parts.
it is not referring any file.
we can rotate any degree using the mirror all concept . if u want rotate the component 90 degree, u'll have create 45 degree plane according to the intersection plane or face.
then use mirror all.
the object is just like twins which is joining the mating face or your new plane.
now u will have to create one linear surface in the new plane (this should be bigger than the entire part model)
now use suface cut . give dirrection to cut which is in original part direction.
now u can get miirored individual part.
why i'm not using view orientation, if my client clicks the view orientation to reset , entire model 'll be going to original old model.
that's why i'm not using view orientation.
thanks
angd expecting comments...
regards,
murugan S
