dum question: v = Ldi/dt
Fellas,
I am having trouble understanding a basic concept. What I would like to know is how, via what mechanism, the voltage spikes in an inductive load. Lets say that you have an inductor hooked up to 240 VAC. The voltage will raise according to the rate of change of current times the inductors value. This obvious. But how does the voltage increase if the voltage source is a transformer. The transformer does not care what is load side of it, right (assuming you're not drawing a boat load of current)? If that is the case, how, again via what mechanism, does the voltage increase?
-AT
-AT
RE: dum question: v = Ldi/dt
The instantaneous change in current present in an AC circuit (or a DC circuit turning on or off) causes a change in the magnetic field which induces a 'back emf(or voltage)' to oppose the current change.
This voltage is measured across the inductance and has no relation to the applied voltage of the circuit, but rather to this change in current.
In steady state the Voltage drop across a inductor is minimal, compared to when there is a sudden 'change' in the current. This also explains why they are effective as reactors to limit inrush or a short circuit current, while having negligible impact during normal operation. During a 'sudden change' more back emf builds up, source voltage remains constant and the through current is limited.
It is obvious if:
1. I2-I1 is very high, and
2. T2-T1 is very small (short IGBT switching time)
then
v(t) will be very high. However, if 1. is not so high and 2. is high, then v(T2-T1) will not be that high. This is the secret behind the zero voltage switching (ZVS), which results in I2-I1 very small or negligible, and there are no significant spikes and harmonics.
-AT
Fellas,
///Is it?\\\
///The voltage on the transformer secondary may only increase, if there is an induction load, which you mentioned above that the understanding of the increase is obvious.\\\
///Not quite. The transformer will see different voltage if the interrupted load is resistive:
Etr=I x R
If I is switched I=0 Amps, Etr=constant Volts, since R is an infinity. Therefore, there is no spike and no transient on transformer secondary side. However, there will some transient on the primary side of the transformer (similar to the switch phenomena explained below)
And different voltage, if the interrupted load by a switch S is inductive L with some circuit resistance R.
When time t=0 sec, i.e. in an instance when the switch resistance became Rs,
Uswitch=Etr + Uc = Etr(R+Rs)/R = I(R+Rs)
where
I is current flowing is the series circuit consisting of transformer secondary winding voltage Etr, Resistance R, Switch Rs, and Coil L.
Uswitch is voltage across the switch contacts
Etr is transformer terminal voltage
R is resistance of the circuit (coil L is assumed to have Rcoil=0 Ohms)
Rs is resistance of the opening switch path, i.e. variable resistance in Ohms,
Uc is variable voltage across the coil inductance, i.e.
Uc=Etr x (Rs/R) x exp{-[(R+Rs)/L]xt}, in Volts
t is time in seconds
If Rs equal to infinity is inserted in the circuit instantly with t=0 second,
then
Ratio=Uswitch/Etr would be equal to infinity.\\\
///As shown above for the transformer secondary side. The transformer primary side transient analysis involves the transformer electrical equivalent circuit and its secondary load circuit, which is more complicated case because of nonlinear magnetization branch impedance Zm.\\\
The analogy which could be drawn
v = L*di/dt
F = m*dv/dt
Voltage plays rols of force
current plays role of velocity
inductance plays role of mass
Now, what is the analogy for rapidly decreasing current flowing in an inductive circuit... accompanied by a spike in voltage?
Rapidly decreasing velocity of a moving mass.... accompanied by a spike in force.
The only confusion on first-glance is whether the spike is a cause of effect of the rapid decrease. The answer imho is both. Spike in voltage like spike in force is always matched by equal and opposite voltage or force from the remainder of the system.
-Andrew Thoresen
As far as the 'momemtum' analogy, imagine something of a certain mass traveling at a certain constant velocity. The greater the mass(inductance), the harder it is to change the velocity(current), or, for that matter, the direction of the velocity.
-Andrew Thoresen
Inductors essentially add "electrical momentum" to a circuit. This is very analogous to the momentum of water flowing through a pipe.
Have you ever heard of or experienced water hammer? If you take a long long pipe, maybe a long coil of pipe, and run some water through it at a high speed, and then quickly shut off a valve at the far end, the water will violently slam into the end of the pipe, making a loud banging sound, sometimes with destructive force. All this despite the pump itself not really generating all that much force.
Similarly, you can slowly pedal a bike up to maybe 20 or 30 miles an hour, without a great deal of force or effort. But slam that bike into a brick wall, and a WHOLE lot of force is generated. Enough to damage both you and the bike. The force you exherted from your feet, though, would likely not have been sufficient to bend the bike frame. Where did the extra force come from?
The key concepts here are conservation of energy, and the rate of energy release.
-AT
More realistically, you'll actually usually get a current INRUSH with AC, until the magnetic field is stabilized. This will actually lead to a voltage DROP.
So, in short, there would be no spike when the breaker was flipped on. The spike in voltage comes from the rapid decceleration then, right? Electrical Pete said "Rapidly decreasing velocity of a moving mass.... accompanied by a spike in force." Does he mean, a spike in the force the other direction. If you're driving your car, and you slam on the brakes, the car slows down rapidly due to the brakes applying a large force in the opposite direction you're traveling. Is this the spike in force he's talking about?
-AT
Re "Does he mean, a spike in the force the other direction. If you're driving your car, and you slam on the brakes, the car slows down rapidly due to the brakes applying a large force in the opposite direction you're traveling." -- careful, it gets a little tricky determining the direction of the force. Your car is actually putting a force on the brakes in the same direction, and the brakes are putting an equal and opposite force on the car. With the bike analogy, is the bike putting a force on the wall or the wall a force on the bike? Really, there's two equal and opposite forces, but the bike is where the energy's coming from.
1: 240 VAC is applied across the inductor
2: The current begins to increase slowly through the inductor
3: the polarity switches on the 60 Hz signal
(here's where I am unsure of what exactly happens)
4: The voltage starts to rise on the 60 Hz, incoming signal.
5: back emf is produced (as the momentum of the current is still in the other direction)
Shit, I am lost. I understand physics I just have a tough time grasping this concept because it is tough to visualize.
-AT
Once you're in steady state, the momentum of the current means that it will actually lag behind the voltage waveform -- there's a phase shift. Mathematically, looking at V=Ldi/dt, since V is a sine wave, then I is a cosine wave (integral of sine). That's essentially a phase shift.
For a mechanical analogy, imagine you have a spring in your hand, with a weight at the other end, and you bouncing the weight up and down using the spring. Everything's going boing-boing-boing, etc. And it's all going at the same frequency. But you'll likely find that your hand and the weight do not reach the uppermost position simultaneously. Rather, there's a time delay (or a phase shift) between when your hand and the weight reach the uppermost point.
See http://www.physics.brandeis.edu/phys29a_2003/AC.pdf , page 252 (262 in the PDF file), Section 9.8.5., for a nice description of inrush currents. Wherever it says "transformer", just think "inductor."
The di/dt is happening BECAUSE of the voltage you applied. YOU applied the voltage, and as you connected it to the inductor, you DEFINED the voltage. The voltage is the cause, the di/dt id the EFFECT. The inrush current won't cause a voltage "ping", it is the RESULT of the voltage you applied.
As a power engineer, I tend to think of inrush as a rather instantaneous event that happens, like, BANG, when you turn something on, and then quickly decays out. Viewed in terms of steady-state operation, it's "sudden".
In terms of the waveform, though, yes, it rises smoothly and essentially exponentially from zero. Viewing the first few cycles, it is "slow".
Yes, if you quickly make and break the circuit of an inductor, it will cause a high voltage on open circuited inductor, the very phenomena used to advnatage in striking the starting voltage to 'start' a fluorescent lamp by switching a inductor called magnetic ballast. (its another matter that now a days electronic ballsts have taken over but performing the same task). The initial strike voltage is in the range of 1500 to 2000V, while the supply voltage is rated for 120 or 220V.
You can get a voltage spike on opening the circuit. But you won't get one on energization.
Rapid sequential make-break-make-break can add an overvoltage each time, up to something like 5x system voltage.
Thank you all for posting - this discussion is really helping me understand it thoroughly. I always knew the mathematical formulas - sadly this was enough to get my by school without having to understand it thoroughly.
///Some formulae in modern engineering and science are so much detachec from reality that are dificult to explain them in something real, e.g. various transformations.\\\
Let me set up an example and see if this is exactly analagous to the voltage spike phenomenon. Lets say you grab a hold of your friend and you shake him, slowly pushing him, and then slowly pulling him. After you have pushed him, he begins to move away from you (bear in mind that you are keeping your hands on him the whole time). As your arms extend and he begins to exert a force, pulling you with him. Exactly at that time, you start to pull him towards you. It takes more force to pull him towards you at this point because the momentum is carrying him the other direction. This larger force you exert is exactly the same as the voltage spike. lastly, is V = L Di/Dt like saying you cannot change velocity instantaneously in nature? You guys are really helping me put everything together here.
///It is highly commendable to seek thorough understanding of the mathematical relationships. However, the advent of software and software calculations changed the way the engineering and design are performed. Often, the most important part is to correctly interpret the input data for the software, correctly input data into software, which then guarantee the software correct output, if the software was properly verified and validated. This is a current trend. It means that to produce the required work, the software used formulae are not necessary to know, may be very difficult to understand and not really needed. However, it is convenient to know how to spot check the software output. That is where the understanding of relationships, analogies, proportions, etc. become good to know.\\\
-Andrew Thoresen
Thanks for all your responses. After going over this time and time again, one thing is clear...the voltage spike will occur when the circuit is opened.
One more question...In steady state conditions will an inductor act as a short circuit? I know that an inductor acts a short circuit in DC sitautions, but I am talking about steady state AC here. I think it does.
-AT
P.S. You can see that for DC the frequency is zero, so the impedance is also zero, therefore the inductor acts as a short circuit.
-AT
Gentlemen,
///Not for AC, only for DC or the DC part of composite of AC and DC, e.g.
i=(Vmax/|Z|)x[sin(sin(wt+alpha-theta)-exp(-Rt/L)xsin(alpha-theta)]
The component with exp is decaying because of the inductance causing the short circuit to the DC and resistance, in the circuit.\\\
///No, it does not since XL = 2 x pi x f x L. For DC at steady state, the XL = 0 Ohms.\\\
The lower the frequency, the more an inductor looks like a short and the more a capacitor looks like an open circuit.
