Aluminum Welding
Aluminum Welding
Aluminum Welding
I am trying to determine the strength of a fillet weld when applied on 6061-T6 Aluminum.  I use to have a sheet that had simple formulas for determining the yield strenght on different types of welds, but I seem to have misplaced it.  Also, what material is usually used to weld on Aluminum?  Thanks in advance.
RE: Aluminum Welding
Perfect!  Thanks a lot.
