Hi, I really need some input on:
What is the state of the art in active AV mounts were limited space and weight is the main consideration? Who are the leaders in this field?
The Av mounts are to be used to support an optical bench under broadband excitation and fairly high g loads (10g ish)
I believe the power reqirements may be the main problem...
Thanks in advance
John
Thanks in advance
John
RE: Hi, I really need some input on:
TTFN
In general, there are two schools of thought on this subject, hard-mount and soft-mount. Since linear vibrations do not necessarily affect line-of-sight jitter, there is some disagreement as to which way is best.
The angular motions are dealt with using air-gap torquers controlled in a servo loop with 2 or 3-axis gyros as the instrumentation. Sometimes the payload is mounted ona smaller set of gimbals to remove some of the inertia. The outer gimbals are then driven by a separate set of motors and follow the inner gimbal.
The original patents date back to the mid-70's and there has been little change since then, concept-wise.
TTFN
