Elastomeric and AV mounts
Hi, I just have a couple of areas i need some input on:
1/ What is the current state of the art for elastomeric mounts over the full -55 to +80 deg (ish) temp range - resonant frequency stability and damping? What suppliers are the leaders in this field?
2/ What is the state of the art in active AV mounts were limited space and weight is the main consideration?
Thanks in advance
John
Thanks in advance
John
RE: Elastomeric and AV mounts
What i did found when limited space is available :
3M™ Ultra-Pure Viscoelastic Damping Polymer 242F04
http://products3.3m.com/catalog/us/en001...
but that was for a high speed application
The other way I used in the past is to work directly with a silicon manufacturer (NUSIL in my case) to play with different formulations.
Good luck
John
Try this manufacturer: Trelleborg-Novibra http://www.trelleborg.com/industrialavs/
They know what they're talking about, have a wide range of product and they sell almost every where in the world.
OkdB
Elastomeric mounts may give you a problem under the wide temperature range and high g-loading for aircraft applications. You might want to consider helical isolators:
http://www.springcompany.com/jes2/isolfr...
pj
A well specified elastomeric 'hydromount' with built in low frequency hydraulic damping could be the answer, as they exhibit high dynamic stiffness, and are able to absorb high 'g' shocks. Freudenberg (www.simrit.com) and Continental (www.schwingmetall.de) and lord all have these parts. -50 to +80c should be possible with these parts. Barry Controls also have a range of air damped parts for instrument mounting applications.
Tom
Lord developed a friction mount which acts almost like a hydraulic mount but without the temperature dependance. Coupling it with silicon in some way (keeping in mind that silicon does not have good abrasive resistance) should give you pretty good dynamic properties.
I suggest you find silicon suppliers who have a NVH lab. Their engineers shoulb be able to work with you and find (or create) the best solution for your application. If you look for a large quantity of mounts yearly, Lord should do it for you. If not, go to a small rubber company.
