Release compatibility problem?
Hi
I'm having a problem viewing files in V5r9, that were make in V5r11.
Could be a release compatibility problem?
thanks
RE: Release compatibility problem?
Hi
Catia files that were created in R11 are not compatible with R9. You can try to make them compatible by runing the downward compatibility batch file located in tools / utility. If that doesn't work first try to run a clean (CATDUAV5 batch) on the files.
Hope this helps
