TI 565 PID Loop
TI 565 PID Loop
I have a new PID Loop that produces a saturated, 32000 bits, output. The loop flags idenify the loop is running in auto mode. Forcing different values into the Set Point still results in a saturated output. If the Reverse-Acting Loop Parameter is enabled the loop output will go to 6400 bits and remain there. Does anybody have any suggestions? Thank you.
RE: TI 565 PID Loop
RE: TI 565 PID Loop
RE: TI 565 PID Loop
is the loop in cascade mode?
is the loop enabled?
What is the address of your PV? wx, wy or V
Are you using Ramp/Soak?
Ken
RE: TI 565 PID Loop
RE: TI 565 PID Loop
