Hi everybody,
I've been wondering for a while about the benefits and trade-offs that are involved in using spoilers for lateral control of an aircraft. Although a lot of work was done a long time ago on the subject (by NACA and NASA), spoilers only seemed to show up on transport aircraft. On any other aircraft, spoilers were only used as speed brakes, and done mostly by modifying the basic aircraft (Cessna 40x comes to mind).
I balance the pros and cons this way:
Ailerons:
Even when retracted, there's a drag penalty due to the gap,
Take up valuable real-estate at the trailing edge that could otherwise be used for flaps,
Rotate the aircraft around its central axis,
Induce a yaw opposite to the bank,
Require balancing to prevent flutter,
Simple actuation,
Continuous effectiveness,
immediate responsiveness,
positive feedback,
Ineffective and sometimes spin-inducing in a stall,
Addition of weight compared to flap or just plain trailing edge is small.
Spoilers:
When retracted, do not intrude on the wing surface at all,
Allow flaps to use almost the whole span of the wings,
Rotate the aircraft around an axis offset from the central axis,
Induce a yaw following the bank,
No balancing required (I think),
Simple actuation (no big difference from ailerons, really),
Response delayed as spoiler extends thru boundary layer,
Feedback not necessarily positive but easily designed in,
Effective in the stall,
Maybe heavier than ailerons, depending on actuation system.
Obviously, I've had some time to ponder, but what do the experts out there think? Why aren't spoilers more common, particularly in GA aircraft?
STF
