electro hydraulic turn over machine 10 ton capacity
I need to choose a turn over (upside - down) machine to turn a mould over 90° from upside position to down or down to upside. Muold weight is about 7 ton.
I´m using to do this operation with a 30/5 ton overhead crane but there is a risk in this manner due to 5 ton hook maybe is handling more than nominal capacity 5 ton when the mould is turned over.
Can you recommend any brand of machine to do this?
Thanks a lot
atvargas
Thanks a lot
atvargas
RE: electro hydraulic turn over machine 10 ton capacity
