3DPOLY line
3DPOLY line
3DPOLY line
Hi
I am trying to draw a 3D line using autolisp's entities. The
code looks like this:
(setq i (- 0 1))
(entmake (list (cons 0 "POLYLINE")     ; Object
              (cons 100 "AcDbEntity")
           (cons 8 "L1")           ; Layer name
           (cons 100 "AcDb3dPolyline")
           (cons 62 3)))           ; Color
(repeat indx          ;indx= size of the array ptlst
                      ;which holds X,Y,Z coordinates
(entmake (list (cons 0 "VERTEX")
           (cons 8 "L1")
           (cons 100 "AcDbVertex")
           (cons 100 "AcDb3dPolylineVertex")
               (cons 10  (nth (setq i (1+ i)) ptlst))))
(entmake '((0 . "SEQEND")
           (100 . "AcDbEntity")
       (8 . "L1"))
This just produces a 2D line. I tried to extract the entity info as: (setq e (entget (car (entsel)))) and selected the above line. It produces:
(100 . "AcDb2dPolyline") (100 . "AcDb2dVertex") etc.
On the other hand if I use the same data set and read it as a script file it produces the correct curve.
Could any one tell where I am doing wrong in the above code?
Thank you
MKV
RE: 3DPOLY line
try "3DPOLY" in lieu of "POLYLINE" maybe ???
RE: 3DPOLY line
Hi...
Is more easy with the ForEach function.
(command "_.3dpoly")
(foreach pt list-point
   (command "_.3dpoly" pt)
(command "")
the list-point variable have all points of the 3DPOLYLINE.
